cyclops222
- Joined
- Mar 21, 2024
- 2,606
Why use a strap ????
Do you do it by yourself ?
Scuppers are there to allow water to drain out of the splash well should the need arise. Plugging them is never a good idea. Are the scupper flaps in place?It has a 250lb driver. But we did move a battery to the front and it did not take on water while unloading and loading. Strap was loose. Just a steep ramp and too much weight in the back. No water coming in the drain holes. all plugged. It will come over the transom.
