cyclops222
- Joined
- Mar 21, 2024
- 2,660
Blown head gasket can be to....water ...exhaust ....intake or a oil channell.
Oh no that is a bummer.Alright. Sorry it’s been a minute to retest. Bought a new compression tester and here are the results…
#1 - 150 psi
#2 - 90 psi
#3 - 145 psi
#4 - 150 psi
Did a wet test on #2 and minimal change. Slightly over 90.
Could it be the valves for #2?
If I had a blown head gasket I would have two adjacent low numbers correct?
If it was the piston rings then the wet test would have increased the numbers?
