Pvaughan23
- Joined
- Jun 26, 2025
- 21
If yer in, yer in.I knew these comments would come in, and I knew what I signed up for with this boat. I plan on learning to do fiberglass, any wood I'll replace and seal myself, I've got a plan, the resources, and the 70HP Evinrude Hustler Outboard is next to it on the ground. Just got the stand built for it to keep it vertical and cover it. And this will be my own boat for the foreseeable future.
Between my passion for this restoration, and the fact that I've got knowledgeable experts as my next door neighbors, I'm pretty much set for any problems that may occur and will have help getting any parts I may need. A lot of the seats will come from FB marketplace or somewhere, but I've been trying to find a brochure or manual just to see what they used to look like so I can plan out where I'll put the front decking over the bow and things of that nature. I've dealt with a lot of stress and things not going the way I'd want the last 3 years so with this boat, I've found a new motivation and have a goal to reach which is just having this boat water-ready next spring. But with the repainting and all that I'd do more research into it when I get to that part but I was originally planning to just use marine paint specifically for fiberglass. People have suggested the gel-coating but I see that as unnecessary for a boat that'll be mine for the next 50 years or whatever I get out of itI have a hangar to put it in and work on it under dry/warm conditions all winter, don't have any sort of relationship to keep me distracted and from 8am to 8pm every weekend I'll be using to work on the boat. After this weekend I should have the fiberglass and flooring completely done or at least most of the way
So, I would've been suspicious of it, but honestly it looks great and held up this far with keeping things sealed up down there, and the guy I bought it from already specialized in doing work like that and I trust his workI would be think the already done below deck stuff would be sus. And unless the fiberglass is sanded and cleaned to perfection the flex seal will not adhere and if you think it needs it that would tend to tell me the previous work is even more sus.
All that said, de capping is the best first step to see what you have.
Yeah, I know the feeling. Pretty much every day for like 20 years or so. Just don't place too much importance on this being the thing that needs to go right. If it gets to be more than you expected, or you screw up and have to do something over, no big deal. Take a break for a bit, it'll still be there.I've dealt with a lot of stress and things not going the way I'd want the last 3 years
I'm just coating the plywood underneath that'll be touching the stringers with flex seal, I'm thinking since it settles tacky it would create a better seal around the edging and such. The top of the plywood will have raptor Lining, then carpeting on top of that. The original floors were gone when I got it. And the listing was only 24 days old when I bought it so I can assume about a month to a yearDon't use flex seal for an undercoating. You want a good epoxy bottom paint or anti fouling if you put anything on the bottom.
