Let me preface this by saying I'm very bored and mostly just curious as I found it odd... and I'm not asking how to trim a boat nor am I going to go in depth on procedure... just a general outline: I've always done it the same way and it's how my boat responds best. Drive full down, hammer down, once the boat is out of the hole (bow levels out) trim up to best performance. Any boat I've ever run that always was the best way to do it... then 2 weeks ago I was talking to a friend and he said his plows if you do that and doesn't react well... curious I asked him his procedure and he said he trims to his running angle then hammers down and it just pops up. He then leaves it alone...
I didn't think anything of it until I was talking to a few other people and they said they do the same thing. Both those boats are quite large by comparison to mine and both have a ton more power than I do as well as weight. I know if I do that on mine I get a lot of bow rise. Does come up on plane albeit slower. I know this because I've slowed down below planing speed testing props to see how they react if you dump then try to come back on and they all did the same thing. Some more than others but all did it. I am going to assume a heavier nose may also effect it.
