2014 GMC Sierra AC
Redrig
Master Chief Petty Officer
Hey Scott , FYI on the acetone .
I did this exact thing 2 years ago on my 91 bronco , the interwebs says don't use acetone , even though its a great flush , once you get the vacuum pump on there its very volatile and the fumes / pump could make everything go boom .
It's probably overly cautious , but thats why I went with the standard flush stuff.
And hold the vacuum for several hours to ensure the system is nice and tight.
Good luck
since today is a half day, will start teardown around noon..... unless its raining
wouldnt be my first explosion, however will be working outside in the breeze, so not too concerned with vapors
Currently raining....... Out of nowhere
Glitter fairy dust from the evap coil
Cleaning out the lines (first flush)
Misc photos of tear-down
Wire brushed the melted rubber off the damper, then hit the damper with a rattle can of paint
Have 2 new condensers thanks to Amazon screw up
Just waiting for rain to stop to do second flush with acetone, then final with AC flush
Then assembly
Finished up today
Used a gallon of acetone and a can of flush to clean the glitter fairy dust from the hoses and evap core
The acetone swelled the seals in the cheap Amazon blow gun in the flush kit
Did all GM parts for warranty reasons, even though there are better built condensers out there like the units I used 3 years ago from NAPA
Adding the oil to the compressor took nearly 30 minutes of dribbling in oil and turning the compressor
The manual says 0.6kg of freon or about 21 oz. However the gauges say it's closer to 28oz. Pressure was low at 170 psi until I added another 6 oz, then high side got up to 300-305psi, low side at ~50 (94F ambient temperature)..... Perfect.,.........
Then my 25 year old manifold hoses blew. 3 pin-holes in the high side.
Tried adding more with just monitoring the low side, however I can't tell if I am under charged or over charged.
Ordered a new set of hoses, they arrive Monday
flashback
Nice write up Scott, almost have me convinced that I could do this, how did you determine what to replace. Did you keep all the old lines and stuff. My ac hasn't worked in years, I used to get by adding a can every summer but that became twice a summer. It might last a day or two now.
The compressor locked up, so the compressor needed replacement
Every time you open the system, you replace the H block and the drier (in the condenser on the truck)
The condenser in the truck is a 2-pass so they can not be flushed. So have to replaced.
The lines and evap core can be flushed.
All new seals, the proper oil per compressor and done ..
Put some die in the system. Find out where the leak is
flashback
My old truck is a 2001 Sierra 1500, has several small things wrong with it, and I don't use it often anymore, I will get some dye and see whats leaking if I can get off my butt.
You will need a UV light and the special glasses. I got mine from an auto store about 30 years ago, Amazon has them for about $10
