Voyager NY
- Joined
- Aug 20, 2025
- 7
I recently purchased a Certified Pre Owned (CPO)engine from Doug Russel Marine. The engine was installed and at first start up i noticed a high vibration from the engine , this is before the drive was installed. The engine was aligned with the coupler ,drive installed and boat launched. The vibration was immediately apparent while under way. After reporting the issue to the marina mechanic it was thought to be a misfire. Now after extensive evaluation by another certified merc mechanc and mercruiser tech support the vibration at all speeds is still there.This is what has been done new plugs cap and rotor change engine coupler, remount sea water pump(it fell off) change motor mounts, replace oil pressure sender(it fell apart) oil changed from 25-40 to 25-50 My question is does anyone out there have a 409 and have you experienced excessive vibration (the whole boat is vibrating to the point everything is shaking, coffe cups jumping out of the holder.
Please help
Please help
