Clanking/rattling sound after prop change
Mc Tool
Master Chief Petty Officer
Are you using fuel with a high enough octane rating ? Is it fresh ? , was the new head gasket the same thickness as the old one ?
Joshto
Regular fuel. Nothing has changed. 'm just going to check the timing proactively.
Question is, is 1 btdc or 2 ATDC?
kd4pbs
I know this is an old thread. Let me know if a new one is required.
Revisiting the timing topic (I'm going to make sure it's all good after 3 years), I wonder if I misread the manual.
If I strictly follow the serial break of manual 26 page 222, my engine should be 2 degrees ATDC (note #4), not 1 BTDC.
Is that right?
0L375837 > 0L341000.
Yes, that's correct.
