Question regarding 1999 Volvo Penta 5.0GL and power to the fuel pump relay
alldodge
Wouldn't be the first time the carb needle valve got stuck closed and the float does not have enough weight to bring it back down. Might need to shoot a small amount of compressed air into where the fuel line connects to carb
ESGWheel
Master Chief Petty Officer
This is good news except for the no squirt part :)
To be sure I understand what you have done, I am going to restate in my own words, please confirm if correct: By jumping out the relay you have confirmed its pumping gas all the way up to the carb. Correct?
Now did you leave it running for 30 or 45 seconds (heck can just leave it running) and then stroked the throttle looking for a squirt?
  • This is the part that I am usure of > did you provide enough time to fill the carb float bowl back up (vs just ‘fill the line’)? Hopefully my question make sense.
Here is a vid I found showing the squirt to look for link. If indeed you do not have a squirt, then its carb rebuild time.
Also, does not matter throttle lever forward or reverse, the carb only knows closed to open back to close. You may have noticed there was no difference in movement of the linkage at the carb regardless of moving the throttle lever fwd or reverse.
Garutlan
Will take a look at this and see. 👍🏼
Garutlan
That was my question to myself as well, whether I gave sufficient time to fill the bowls. Will try again and update y’all. 👍🏼
