Mercury TT
Chuck4741444
I dont have the model # I have 99 200 TT. Does it interchange with an 86 TT?
Moved your thread to the outboard forums.
what is wrong with your T-n-T?
Dukedog
only if you change tha "complete" TnT assembly.. yours has different pump and motor and uses (two wire motor) relays.. tha '86 uses (three wire motor) solenoids... think CDI makes an adapter kit to use tha relays with a three wire solenoid system....
