Very good advice, specially the the swim back to where you entered the water part.If you ever fell a tingling while swimming. STOP And swim back to where you entered the water. Save your own life.
I think you may be on to something here--especially since the magnesium anodes which are installed correctly are doing essentially nothing. I have thought maybe I got zinc by mistake so I will check that as well. For next season, I will go back to running aluminum anodes--they can't possibly work less either way.That was my understanding as well, but it seems that different chemicals in the water, specially as the water gets warmer, tend to react with the aluminum alloy more than with the magnesium. That was the advice I was given by my local western Lake Ontario boat mechanic /small marina owner. He also claimed that close proximity to a power plant or an industrial seized power consumer throw the balance off in one way or another. High or low calcium content play a role as well. It has been a while since I played around with organic chemistry so I may be on a wild goose chase. Probably the best info available will be other boat owners and marine technicians nearby your slip.
Thinking more about this, I think you are on to something. @tpenfield linked his thread where he added an anode to his gimbal ring because of similar corrosion issues. In that thread, someone also pointed out that he had broken/detached trim sender wires which would supply 12 volts with the engine on to the surrounding area (the gimbal ring). So, putting 2 and 2 together, the common denominator between the two cases is the trim sender wires dangling in the water. I am going to detach them from the engine block so they do not supply 12 volts for next season.another cause could be a incorrect charger wired incorrectly .Second place it the trim sender .With the key on there is a constant 12 volts at the sender. If the voltage is leaking from the wires you will get the same symptoms .You can rewire the system so that it only operates the gauge when the buttons are depressed
Either way I have now disabled them. Seeing as the corrosion was closest to the wires, I believe this was the issue: while running, 12 volts were applied and a "battery" was created causing the electrons to flow from the open circuit into the non-conductive freshwater to the least noble metal, aluminum--aka my gimbal ring; the situation is further exacerbated by the ring's contact and proximity to the carbon steel steering pin and much stainless: hinge pins, swivel pins, etc. Due to the current, the gimbal ring thus dissolved a bit, while the steering pin rusted and the stainless pitted. The further away from the loose, dangling wires one's eyes travel, no corrosion is discernible--thus the drive itself is a-okay and well-protected by its anodes (which are barely being tested since the water's of the UP are so clean, clear, and cold).Most trim senders are wired to be energized when the ignition is on, so those wires shouldn’t be getting any voltage when the ignition is off…
Even tho I’m 100% in salt water it’s not a marina where boats can be on shore power so stray current really isn’t an issue…
not sure where you get your magnesium annodes from, but I also had some corrosion on a fresh water alpha gen 2, Lift kept and there is no shore power to it. My hoist runs of 12 vdc. I run a revolution 4 prop which is a big chunk of SS.Either way I have now disabled them. Seeing as the corrosion was closest to the wires, I believe this was the issue: while running, 12 volts were applied and a "battery" was created causing the electrons to flow from the open circuit into the non-conductive freshwater to the least noble metal, aluminum--aka my gimbal ring; the situation is further exacerbated by the ring's contact and proximity to the carbon steel steering pin and much stainless: hinge pins, swivel pins, etc. Due to the current, the gimbal ring thus dissolved a bit, while the steering pin rusted and the stainless pitted. The further away from the loose, dangling wires one's eyes travel, no corrosion is discernible--thus the drive itself is a-okay and well-protected by its anodes (which are barely being tested since the water's of the UP are so clean, clear, and cold).
Seriously, the water has only been ~67 and ~62 degrees, in Lakes Michigan and Superior respectively so it is not that conducive to corrosion in any way--as such, this whole thing never made much sense to me but I couldn't believe my eyes and the feel of the ring which were not deceiving me.
Also, I have confirmed my anodes are indeed magnesium and they do have small pits when viewed up close. This isn't shocking since they've been in the water only a total of nine overnights (4 and then 5).
I think this thread is solved but only time will tell. Thanks to all for your help!
The corrosion on the gimbal ring is definitely corrosion and not pitting or scale. I believe the source to be the loose, dangling, and formerly-powered trim senders wires which are right next door (and have been since disabled).The "corrosion" appears to be mostly calcium scaling with a bit of corrosion here and there
In situations with dissimilar metals in contact with each other in fresh water an often overlooked and attributed to other factors is water chemistry.
Alkalinity, hardness, and pH interact to determine whether the water will produce scale, corrosion or stability of the metals.
In general, water with a low pH causes corrosion. Ideally, pH should be maintained between 7.0 to 8.5 for aluminum. 9.2 to 9.6. for steel/iron and 8.0 to 12.0 for stainless to minimize corrosion.
Time series of pH at drinking water intakes in the western and central basins of Lake Erie illustrating short-term variability of pH
However, water with higher pH lowers the solubility of calcium carbonate making it more likely to precipitate as scale. "Whiting events" are a know phenomenon in the Great Lakes
Temperature speeds up corrosion however, the effect of temperature on corrosion is complex. Higher water temperature reduces the solubility of calcium carbonate which promotes scale formation and but slows corrosion. Temperature also alters the form of corrosion. Pits and tubercles tend to form in cold water while hot water promotes uniform corrosion
I suppose I could go back to aluminum anodes for next season.In my findings aluminum is best for B3 and fresh water
Also the amount of anodes used must be done with knowing the voltage reading. Adding more anodes will change the voltage readings, so more is not necessarily better
I do not recall if these came from Boat Zincs or Martyr (through West Marine).not sure where you get your magnesium annodes from, but I also had some corrosion on a fresh water alpha gen 2, Lift kept and there is no shore power to it. My hoist runs of 12 vdc. I run a revolution 4 prop which is a big chunk of SS.
I added a mercathode, still getting some bubbling around the prop hub...I had put magnesium annodes from boat zincs on it that were not sacrificing, swapped those for OEM merc ones, they do show signs of "working" and I no longer have corrosion.
I had none of this in same hoist with my old boat running aluminum props on a gen one
I was surprised at how much more ‘active’ the oem ones were Vs aftermarket. Of course this is a sample size of one…funny thing is seeing ADs comment about aluminum is I took off the AL ones that were on there, PO used this boat in brackish bay areas of Deleware.I do not recall if these came from Boat Zincs or Martyr (through West Marine).
