ptclabs.jp
- Joined
- Dec 27, 2023
- 20
It leaves the gauges and the tilt powered as soon as main power switch to the motor is on. When you first turn it on it thinks the motors are running as it sets off the alarm until you put it in stop. It will stop the alarm, but not turn off the gauges or tilt.
What I have tried
1. disconnecting the harness at the motor. It is not being fed from a third part source. It turns it off.
2. pulling both relay in the system. I only know of 2 unless someone knows of another somewhere. tilt and start
3. unplugging the clusters one by one (duel bridge) it is not either of those.
4. Disconnecting all extra wires to the starter. No effect
5. disconnected the alt wire at the fuse bus above the starter. no effect
Things I will try
1. turn off all charging solar, power supplies extra and run the motor, to see if it suddenly goes away.
2. I have a extra single helm harness, piggyback and try.
Does anyone know of anything on the motor itself that could do this? The motor was just reinstalled and it happened a few weeks after. I am thinking harness shorted when motor was out, but I do not know.
What I have tried
Things I will try
