1999 Volvo Penta 5.0 GL freeze plug kits
Garutlan
Anyone know a part number for a freeze plug kit for the engine in the thread title. Was not sure if a GM cross reference would work. Thanks in advance- Geoff
alldodge
Go to any auto parts store and give them the year and GM 5.0 and they should be able to find Brass or Stainless Steal plugs
Should also be able to find them on line at a place like Summitt Racing or Rockauto
Napa keeps core plug kits in stock. marine use brass or stainless. cars and trucks use coated tin
Melling MPE-100BR is for small block chevies from 1957-2014
however if they were pushed out by not winterizing, the block cracked
Agree with post #4.----If pushed out by cold weather then inspection is required.-----They are " core plugs "----And somehow they began to be called freeze plugs.
Remember, the block water jacket should hold 15psi.
the points of failure if it froze will be both exhaust manifolds will have a crack on either the outboard or inboard side, just above teh centerline of the exhaust ports, and both waterjackets will have cracked on the inside of the cam valley, and the heads will crack around the exhaust valve bowls
