Kill Switch Lanyard
pspagna
I have a 1997 seaswirl 170 with a johnson 130 on it. While the boat is running if I pull the lanyard that is supposed to shut off the boat, it doesn't do anything and the boat keeps running. The lanyard does not even have to be connected to start the boat. Any ideas on how to start troubleshooting this? Thanks
first, welcome aboard.
being a johnson, going to assume 2-stroke.
the switch could just be bad. 2-stroke kill switches ground the stator to ground.
so disconnect the switch, and measure continuity both with and without the lanyard
alldodge
In most cases the switch is on the rear face of the throttle control but may be on the helm
The Johnnyrudes of that era had a different kind of kill lanyard. When the lanyard is connected correctly, and you pull it, the button on the ign switch pops out and turns off the ign switch mechanically.
Look for the small button (say less than 1/4") in the center of the kill switch (provided it is original). That must be depressed before hooking the clip onto it. Look at the fourth picture on this:
dingbat
Yep…my 97 has the same setup.
Don’t need the lanyard to start the boat
saltchuckmatt
Yes, my 2009 E-tec is the same. They made that feature so if you got flung, and the cord is strapped to you in the water, your mate could start the boat and come get you.
Not sure I'm a fan but it was perplexing when I first discovered that. Now whether the op has that might be in question. Someone might have installed an aftermarket one and other possible scenarios.
