kbh121956
- Joined
- Jun 30, 2013
- 497
Hello Group, my first Johnson OB. Model number is, 35E78R. The harness that goes to the dash (helm) has been cut. I want to check for spark, compression, etc. I am needing help with the key switch wiring. The wires are as follows
Red/Purple stripe.
Purple/White stripe.
Yellow/Red stripe.
Black/Yellow stripe.
And a Black wire.
Also, what ignition switch do I need? Are factory service manuals available?
Thank you.
Red/Purple stripe.
Yellow/Red stripe.
And a Black wire.
Thank you.
