Tested a 2011 Tahoe Q5i with 4.3L mercruiser and 14 x 23” prop. All seemed to be good except WOT resulted in ~3300 RPM & 39 MPH. Two male adults and 1/2 tank of gas with very little gear on board and water & wind were pretty calm. No bogging noted and engine ran fine for the 2+ hours out there (mostly idling and no wake speed).
Could the prop alone be causing this low rpm or is maybe something else also going on (fuel restriction, throttle issue).
Thanks for any thoughts.
