Bypass oil injection 2000 90ELPTO
Captain Bravo
Hi guys. I just got a 2000 90hp ELPTO to replace a 1973 50hp Johnson on my pontoon. I've been running older boats for 20 years and had several motors, but this is the first one I have had with oil injection. Bottom line, I'm just uncomfortable with it. Maybe because I've had so many problems with boat motors over the years.
In any case, I've read a lot about people debating IF it should be done, but nothing on how to do it. Can anyone give me what I need to do to bypass this system?
Thanks guys.
CB
halsteadmorris
I have a 1996 40 ELPTO and have also deleted the oiler (for similar reasons).
The oiler was deleted before I bought the motor, but I have personally deleted several others. The short answer of “how” to do it:
Plug any line that goes into the tank with whatever seems appropriate. I have had good luck simply shoving a SS bolt into the line and using a hose clamp. Fuel/Oil safe silicone plugs work too. Make sure they are clamped tight to avoid any air leakage. You do not want poorly/unplugged hoses, etc introducing excess air.
You may need to bypass low oil, low flow, etc sensors if you get any alarms.
airshot
OMC oil injection systems have had issues and I would not trust them. But the Merc units have been very reliable from my research. A friend is a retired marine mechanic, says he doesn't remember a Merc injection system failing unless abused. My 1992 injector systems all original and works great. Idles all day without fouling plugs...mine has also been well maintained...
