Can someone send me a picture of the boat capacity plate
rogerlamb123
I have a 1998 Century 2100 walkaround and the capacity plate is unreadable. Can someone send me a copy of the plate for this boat?
Thanks, Roger Lamb
rogerlamb123
I need to replace my 150 HP Yamaha 2 cycle and have access to a 200 HP Yamaha. I just wanted to check if this is ok (capacity plate is unreadable)? Also wondered if anyone else has run that size motor on the 2100 Walkaround.
Thx, Roger
Did you Google the specs?
Or use the Col Reg formula that the USCG uses?
A quick Google search will tell you that your 200hp is fine
rogerlamb123
My 1998 Century 2100 Walkaround has an unreadable capacity tag. I know I can order a replacement but I need to know what the persons capacity is. Ive searched and found that it allows up to a 225 HP motor but can't find the persons capacity info. Can someone with a 2100 walkaround advise what the tag says?
Thanks, Roger
KBB will usually have that kind of info.
If it counts, my 1998 21 foot SeaSwirl dual console cites 200HP as max. My opinion is that it could take more HP, but 200HP is the spec for max.
rogerlamb123
If you are a 2100 walkaround owner I would love to know what motor you have? Also what HP maximum your capacity tag reads (mine is unreadable).
Thanks,
Roger
jbcurt00
Try to avoid posting duplicate topics, even if in different sub-forums
Merged
aspeck
Google says this ...
A 1998 Century 2100 Walkaround features a maximum weight capacity of 2,000 lbs, which includes all passengers, motors, and gear.
