Anyone have a fuel line schematic for a 1985 90hp?
Iamthegump
I've got a single hose and I cannot for the life of me, figure out where it's supposed to connect. It comes off another line with a plastic tee near the starboard side of the lower carb. It's about a foot long and it's just laying in the tray weeping fuel.
Crosbyman
is this it ? #66 or....60 AI info... look for a small nipple or one with a broken piece of tubing
On a 1995 90 HP Evinrude (3-cylinder crossflow carbureted engine), the balance tube drain hose #66 is a small but important part of the intake system.
The balance tube connects the crankcase/intake passages of the cylinders. It helps
:Equalize pressure pulses between cylinders.
That would be a 4 cylinder engine.-----Look for a nipple near the center main bearing.
