PSA for inboard gas owners.....
matt167
I just ordered and got a cheapie. Last time I was out on my boat with my dad trolling around he swore he smelled gas. I’m pretty sure the portable tank for the kicker was just venting a little where he could smell it. I couldn’t find any fumes multiple times even after I pulled it out of storage again with the mooring cover… the little sensor seems to be pretty sensitive and cost $20.
Pmt133
We have a GMI unit and some handhelds with LEL sensors in them. I spend more than 20$ in calibration gases for them a month. I think the $20 unit is a no brainer for piece of mind.
IslandExplorer
Weird how the handhelds are so nice and cheap yet the simplest install it yourself mounted setups start at an exponentially higher price I noticed. I'll probably just do the handheld for now. Do like the idea of an integral sensor with helm console indicator though.. Remember seeing actual mounted analog gauges for this on older boats vs just an alert piezo with a light and switch. Went out of style like the marine manifold vacuum gauge maybe! 🦕😅
matt167
I think the handhelds are so cheap because they sample the air against clean air baseline. That’s why they have that warm up period. The integrated would have to have a different calibrated type sensor
Lou C
The Xintex that I installed back in 2013 has really gone up in price but is still worth it.
Renken2000Classic
I usually smell the exhaust of the blower during pre-trip prep and/or before firing up once in the water, or have one of the kids do it. That only covers that moment in time though.
airshot
Certainly true.
I think a good idea is for the fuel tank coffin so to speak to have vents on the front and rear bulkheads, that helps also with drying out any moisture.
I fill mine at our local fuel station then drive home to its storage. A few miles down the highway vent all the vapors then while stored in my barn it is very easy to detect any leaks. I also keep a couple fire extinguishers in my barn as a just in case. Folks should think about that....anywhere you have flammable fuels stored, be sure to have a couple fire extinguishers on hand. Garage, barn, storage shed what ever, have a couple extinguishers on hand....cheap insurance just in case !
bigblocksarefun
Just in time for an example:
