nola mike
- Joined
- Apr 22, 2009
- 5,970
Seeing the "what tools are these" thread...
Following up with a "tricks that old people know".
I'll start: putting the closed end of a box wrench on a bolt, and using another box wrench on the open side as a breaker bar. Easier said than described. Ok, here;
motoiq.com
Same vane, I have a few pipes that fit over the ends of my ratchets to use as breakers. Or over my breaker bars.
Wrench Tips #7 - The Box-End Breaker Bar - MotoIQ
Wrench Tips Tip #7: The Box-End Breaker Bar This tip is from MotoIQ reader Jeremy Fiel, though I, too have used this simple trick many times. If you're using aā¦
motoiq.com
