Pontoon Questions: Jacking it up while on trailer? & What's this called?
ChazzL
I'm wanting to jack the trailer up a few inches so I can work on the bunks. The bunks are longer than the back of the tubes so I cant brace up and jack the bottoms of the tubes. So my questions are:
1) Is the welded box at the end of the tubes (for mounting transducers, etc.) strong enough to put a jack under? (#1b in photo).
2) What is this called and is it strong enough to put a jack under? (#2 in pic).
3) What about putting a 2X6 across these 3 of joists on each side to use as a base for lifting?
Thanks for any help. Would like to hear opinions.
jlh3rd
1. - no, you'll bend it.
2. - that's the bottom of your motor pod. It is not structural...you'll most likely collapse it.
3. - yes..that can work. The ribs (C channels) are a good support structure.
And the 2x6 spreads the load.
Furthermore:
the toons are normally built in welded sections. Each section is water tight which means there is a bulkhead at that seam. Another good structural point. Be careful lifting/supporting between these sections, or you'll end up like the picture.
ChazzL
Furthermore:
Thanks. Those pics don't look good. If I cut a foot off the back of the bunks is it structurally strong enough to jack the boat of at the rear end of the tubes?
(I'm going to go with the #2 option, but curious if I can use the rear of the tubes).
Jack it up from the deck, not the tubes
Your bunk trailer only works because it supports the whole tube
flashback
why not launch the boat and tie up on a pier, then do the trailer work.
ChazzL
That is certainly an option, but the ramp is some distance and I'll have to haul all my tools. Plus I don't know hpw long it will take. Just much easier in my back yard.
jlh3rd
I would not jack it anything beyond what it takes to raise it and place a support.
I can't tell how high you can jack the rear of a pontoon using that end bulkhead before something "gives "
there is longitudinal support from the toon itself and from the decking but what the bend point is is unknown....maybe a pontoon can be totally lifted at the end with no issue...dunno.
I consider the bulkheads and ribs more of support points than jacking points.
they lift my pontoon at the marina by that "belt" lift machine with the belts positioned on the seams.
Jeff J
This is something I have done a few times to repair trailers and/or give the welder access for repairs on the tubes. I was brought one boat where the majority of the bunk was pushed out at an angle from the tube. Only the front lag bolt was holding it.
As stated by others, stay on the seams if jacking on the tube. Cover as much area as possible to spread the load. Tubes on properly fitted bunks don’t give much access, if any, to jack on the bottom of the tube. Better to use the deck structure but rigging that safely can be a problem given the height along with having a trailer in the way. Lifting one side of a boat to repair a bunk will easily exceed 1,000 pounds.
Lift slowly and no higher than absolutely necessary while watching for problems. It worries me every time I do it.
jlh3rd
I can get under my tandem pontoon bunk trailer and could put a 2x6 across a few ribs . They use these jack screw type support/jacks at the marina. Kinda like a transmission jack. Any access to a something like that?
2 per side with a 2x6 spanning some ribs and lifted just a few inches enough to remove the bunks on that side....rent from a marina?
jimmbo
No Pressure Treated Lumber for the Bunks, as the Chemicals used to treat the Wood, will react with the Pontoons, which are likely Aluminium
flashback
Still say, cut your new bunks to length, strap them down to the trailer and launch boat, spend a bit of time in the parking lot at the ramp to install. Be my choice. šŸ˜€
