ranger335
- Joined
- Sep 6, 2025
- 25
Ongoing/intermittant problem for over a year. Replaced the impeller (twice), thermostats and flushed out the heads and or block using a water hose hooked directly to the hose fittings on the blocks. That was last year. This year I replaced the inlet screens and re flushed. Thought I had it, but no. Did a vinegar and dawn flush like I saw on YouTube with the lower unit in a barrel. Thought I had it, didn't run hot and I ran it for quite a while at full throttle. Took my farmer buddy fishing and never made it to the river, ran hot on the 1/2 mile run in the creek. This morning I removed both heads and there was very little corrosion or anything that would cause a blockage. I don't understand about the water diverters. Mine appear to be swollen but if they are supposed to divert the water why does swollen matter? I have to order new head gaskets anyway, so I'm going to order new water diverters also. PLEASE HELP, the white perch are biting.
