Mercury 50 hp timing issue.
OFF SIDE
I have a 1985 50 hp 2 stroke that's has a timing problem. The stator was replaced, now the engine only starts when throttle is totally engaged. I would suspect the timing is out of sequence and needs adjustments
I have attempted to reference the method of adjustment but having no luck.
The serial number of the motor is 5485447.
Any help would be greatly appreciated.
OFF SIDE
Find attached is what a believe are the adjustment screws for the timing. Can anyone indicate what the screws are ?
Low idel , high speed?
Tks, I can't find any information on the timing
