DP Drives - Strike Protection?
Kosmofreeze
In my 4 seasons of being a DP-SM owner, I finally hit a rock (log?). Hit it maybe going <10 mph. I run an aluminum prop because I believe what I read about aluminum being somewhat "sacrificial" compared to the stainless steel counterpart. The strike wasn't "bone jarring", but I was surprised at how mangled the prop was when I brought it up. It turns out that the prop was well within repair limits and less than $300 bucks later, my props (yes, both of them got hit) look better than new. This got me wondering - does the DP-SM (really any I/O) have any mechanical or hydraulic "safety release" that allows the drive to pop-up in the event of a strike? It seems like O/Bs have this capability.
Horigan
Yes, the trim system has pressure relief valves that provide some protection.
bajaman123
Yes, the outdrive will kick up but generally only when the skeg is hit and whilst in forward motion. Be aware there are a number of conditions that will prevent this from happening...lots of information on the Web.
Best protection is a GPS plotter.----So cheap these days compared to lower unit damage and downtime.
Did a rock strike with a DP290a. Back in 2012. Lost 2 blades (one off each prop) folded 3 more over. And the drive kicked up. Came in with a bad vibration at just below planing speed
It did bend the reverse latch . 2 new props a d some minor repairs and all was good
