How does my 1997 Force 75hp sound
I just removed and cleaned the carb. Replaced the inlet needle. and set idle screw to what it was at before taking it apart. I also changed the spark plugs. Would like an opinion on if it sounds like it's running/idling ok.
  • IMG_5209.mov
Sounds perfect.-----Do final mixture adjustment with boat in the water.----In gear and warmed up.
roscoe
that 75 is a nice motor.
Might even push your Jupiter to the moon.
jimmbo
It sounds Terrible, a complete write-off. Tell you what, ship it to me, no prepaid return shipping required... I will dispose of it for you;)
Drivewayboater2
Sounds just like my 93 Force 70hp on muffs. Agree with racerone. Do the final carb adjustments on the water.
