Powerhead and electronics swap, motor not running right. 200 hp
Johnnyl30y
Backstory....i am a harley davidson mechanic and do a lot of tinkering on boats on the side. I recently traded for a boat with a blown motor. The guy bought and included a complete used powerhead that a boat shop told him would be compatible. The motor is a 1995 johnson 200 venom. The parts powerhead that was included on the deal was missing the stator, timer base, starter motor, and some other things. I stripped the wiring harness off of it, took the carbs off and cleaned them, and then took everything off the original motor down to the mid section. Used the donor block, intake, and carbs (the carbs are noticeably different), along with the original 1995 wiring harness and ignition components.
Got everything assembled, tried to fire it up in test tank and couldnt get it to stay running. It would idle roughly for 5-10 seconds, then due. I kept playing with the idle mixture screws, then the idle timing, didn't seem to matter what I did couldn't get it to idle smoothly or consistently at all. Couldn't get it to rev up at all. Took a known good fuel tank and line off my other boat and was able to get idling a little better but only by cheating and having the throttle plates open a tiny bit. still not good but could Rev it up in the test tank. Took boat on river, would stay idling, but not smoothly at all. As soon as i took off It couldnt get on plane was bogging out and the warning buzzer would go off until I throttled down to idle then immediately shut off. Motor wasnt hot to the touch, but I did remove the thermostats to make sure. This process has repeated over and over.
I have checked compression.... 98-105 all six cylinders. Spark... seems to not be super consistent, all cylinders have spark, only a couple were arcing across 7/16" and not every time. Timing seems very hard to get adjusted. I'm questioning if all components are compatible with each other or not. Please help.
Doubt that optical ignition was used on 200 HP model.----Mainly used on the 150 / 175 model 60 degree V-6 models.
flyingscott
No optical, then at least did you disconnect the qwik start to time it
Johnnyl30y
If that has the optical ignition you need the ignition analyzer.
My problem is that I'm not sure if it had the optical system or not. The ignition components were stripped off the donor motor. Also I'm finding varying answers when searching the internet for this info.
Johnnyl30y
I guess my main issue right now is that I can't even get it to idle with the throttle plates closed all the way as it should. Will only hold an idle with the timing so advanced that it hold the throttle plates open slightly. Also cannot get it to run at wide open throttle under a load. Only in neutral does it rev up like it should.
Johnnyl30y
I have 2 sets of carbs, one from maybe a 1993 model (have 2 air orifice in them) and the original off the 1995 i have. Which ones are better and would i be better off rebuilding and running?
Johnnyl30y
Crazy how hard i chased so many symptoms and how simple the problem was. The battery was simply too low to spin the engine fast enough to create good spark. It would start up the first time or two each time I worked on it, likely from the battery being somewhat charged up, but then nothing. I cranked and cranked on it many different days struggling to figure out so many "ghost symtoms". Tonight the starter bendix hung up on the flywheel and backed voltage to the regulator, frying it. I went to Jumpstart the battery and it ran like a million bucks with the jumper cables hooked up! Battery was sitting barely over 11 volts! I have a spare regulator from the other motor I will put on tomorrow with a charged battery and I'm confident it is fixed. Got a whole fuel system overhaul in the process.....oh well, good to know I have that all tuned in.
