Mercury 200dfi 1997
Hello everyone! I have a mercury 200 dfi engine from 1997. (White Elephant) I had a lot of problems with these engines. These are the first series of direct injection engines and only a few hundred were made. My engine has 1 operating hour, practically brand new. It was hung on the wall of a Dutch sailing school as a demonstration engine from the first minute. I bought it from there. Unfortunately, there are hardly any parts for it because it was redesigned. I would like to use it somehow, I tried to start it but it smoked terribly. Is there any way to use it? Convert it to a carburetor or central injection? I would like to get some advice. I have a Quicksilver diagnostic for it but unfortunately it does not see exactly what is wrong with the oiling.
Thank you very much for the advice.
alldodge
I don't know much about the Optimax but in research it list the linkage rod is out of adjustment or has fallen off.
Could also be the oil tank is being over pressurized, it has a 2 psi check valve
Are the spark plugs coated with oil?
Don't know your serial number but I'm finding parts are here in the USA. Hope someone with more knowledge will comment
Nem sokat tudok az Optimaxról, de a kutatásaim szerint a kapcsolórúd nincs beállítva, vagy leesett.
Az is lehet, hogy az olajtartály túlnyomás alatt van, van benne egy 2 psi-es visszacsapó szelep.
Olajjal vannak bevonva a gyújtógyertyák?
Nem tudom a sorozatszámodat, de úgy látom, hogy vannak alkatrészek az USA-ban. Remélem, valaki, aki jobban jártas, majd hozzászól.
Köszönöm a válaszod!, lehet, hogy nem látod a képeket a hozzászólásomban?
sorozatszám: 0G386502
alldodge
Thanks for your reply! Perhaps you can't see the photos in my comment?
Serial number: 0G386502
Looks like Hungary
Serial number helps HERE is your motor
Been looking for your service manual but for some reason it doesn't show up.
Looks like Hungary
Unfortunately, it was manufactured in this form for only two years, so there are no spare parts available for it. How could I modify it so I can use it?
There is no qualified specialist here in Hungary!
I may be a marine mechanic, but this engine is a completely special case.
alldodge
Wish I knew how to modify
Have read many threads where the oil injection has been removed and the gas has been mixed at 50:1 and just run it
