Prop / prop shaft damage
Kwanza
Hi, I had an unfortunate series of what I thought small incidents recently.
5.2 m Glastron MX175 runabout, with VP sterndrive.
1. Upon returning home with my boat and parking it, I manually pushed the trailer to back it up in my driveway and hit and scraped my timber fence with my stainless-steel prop. Snails pace, fence quite rickety as well. Used boat as expected after this, with no issues noticed.
2. At the boat ramp, I mucked up, and hit the bottom of the ramp (concrete), with my stainless-steel prop, barely above idle. I continued my trip, and upon return I had very minor chips/scrapes on 2 out of 4 blades. Minor, I would say, 1 mm. Attempted to fix it with very fine sandpaper. Used boat as expected after this, with no issues noticed.
3. And yes, I engaged in retrieving boat at the ramp without lifting drive. Stopped the car immediately when I heard the scraping, might have dragged it a meter or less. Bottom of the skegg scraped slightly, not broken, no bend I could notice. I checked prop, it was spinning both ways in neutral, don't know whether pre-incident was spinning easier or not.
Following this, during my next trip I completed an ~10 km journey after this incident. Everything seemed to work ok, had to engage both forward and reverse gears to leave the marina, and completed an ~12 km trip. Then engine cut out. Could not restart it. Would turn over very-very slowly, maybe one turn, struggling. No click from starter motor. Battery showing 12.4 V. All gauges (charge, oil, temperature) indicating correct values. Attempted start with a jump starter pack the Coast Guard had with them, and while it definitely had more juice than my battery, would only do the same. Turn over one or twice very sluggish, forced. Engine has oil, did not overheat, it was in the nominal range throughout.
Now home, I inspected my prop and tried to manually spin it.
In neutral, spins easily in the reverse direction, and I can barely turn it over in forward direction. I wobble it back and forth a bit, turns in forward direction with increasing resistance, no noise, but not a smooth turn. I can almost feel some sort of grinding, but no noise.
In reverse gear, it spins easily in reverse, and locked when I attempt forward spin.
In forward gear, locked when I attempt reverse spin, and the same seizing, hard forward turn.
Is it possible that a small damage done earlier now became a critical issue, and my engine would not start because it knows it can't run safely, as it can't spin the prop shaft?
I'll be taking it to the mechanic, unless there are any suggestions I could try.
My shifter cable is not the smoothest, but from the above it seems the shifting itself is working.
I just read about hydro lock now...possible.
Trying to rotate the engine by hand at the crank/flywheel - not budging. Or barely.
My engine oil (on the dip-stick) was clear yellow/amber color when I checked straight after stalling, it is the same now. Need to see what's in the bottom.
Thank you.
Kwanza
Removed spark plugs. All four dry. Tried turning the engine at the front, where the belts are, I can turn it over manually, quite hard but turns over.
jimmbo
I suspect that the Gearcase is low on Oil and the Upper Gears/Bearings were starved. Most VPs have a Hexagonal Bolt/Screw a the top of the Outdrive housing. It will also be a Dipstick. Remove it and see if there is any Oil on it
Kwanza
Thank you.
Not only was it bone dry, I could hear the hiss of the air rushing in as I was opening the hexagonal bolt of the dipstick. I will next check the drainplugs for any residue/metal shavings. The boat was serviced in April, and I paid for Gearcase oil, gearcase O ring, and O ring top gearcase dipstick.
I presume the moral of the story is to really check all your fluids as per the manual. I did check engine oil twice lately, but no gear oil. After all, it was just replaced.....was my thinking. I don't think I'll try to do anything else with it until my mechanic has a look.
Removing the bottom drain plug, there were no residue stuck to the magnetic bolt, but some oil came out. Maybe ~25 ml, still seeping out when I put the screw back. Oil was clear, not milky, no residue or suspensions of any kind. Will eventually drain all to see how much is missing.
Thank you.
Kwanza
Following up this issue, @jimmbo was spot on. Top bearing shredded to pieces. During my previous service 1.5 l of gear oil was added, when it should be a minimum of 2.1 l. Whether there's anything else, remains to be seen. Engine working OK.
Kwanza
Further update on this issue. After pulling off the drive, confirming that engine was running, and replacing the damaged front and rear bearings (nr 17 and 18 in the above diagram), things seem to be running.
The mechanic who did the work tells me that there seem to be some residual noise coming from the top box, however he did not want to pull out this vertical shaft. He said he ran it for 10-15 minutes, and he was hoping that the noise would go away as the gear oil gets into all the nooks. Apparently, he can still hear some noises and can't guarantee things will last, as there might be some further damage in the top part from the seized gearbox.
As of yet, not sure what else I can do, will have to pick up the boat and try it out on the water. Whole drive replacement might have to be done at some point.
alldodge
Looks like the mechanic did you a dis-service.
Captain of the Double G's
He meant to say " they forgot to refill the unit at the last service " !
Time to get handy ( showing my age with that word ) and do some of it yourself.
Oh, get a repair tech, not a mechanic ( if you know, you know ) no disrespect intended.
jimmbo
Who did the previous Service? If you have documents that state that they only put 1.5 liters of Oil in the Case, and then sent the boat on it's way, you do have case of Negligence on their part, and that they should be paying for the Repair/Replacement,
Kwanza
Well, I was quick to doubt the previous service, however in my rush didn't notice there were 2 x 1.5 l gear oil charges on the invoice. Oil must have leaked somewhere else. Saga continues.
jimmbo
When you removed the prop, did you find a mess like this?
Kwanza
Haven't seen any from the outside, and the boat mechanic who changed the bearings did not mention finding any. Will ask him though, I'll be bringing the boat home on Tuesday after having been away.
My current theory is that when I scraped the skegg at the end of my previous trip, while there was no visible damage apart from scraping, some seals would have damaged. With no signs of oil leak in my carport, the oil would have been forced out once on water.
Will have to check whether a pressure test has been done with the new bearings and new oil.
Kwanza
There was no tangled-up fishing line or any other mess behind the prop.
I attach a one-minute audio recording of my drive, in gear, just above idle, on land. Would be interested in personal opinions of others. Would this be noisy to the level "don't go anywhere before you swap your top unit" or "mine has had the same noise level for the last 5 years".
Only had this boat for around 8 months, used it for ~15 trips, longest was ~60 km, never really paid attention to gear noise, in water or on land. Might be noisier than before, but I honestly can't tell.
Thanks all.
View attachment 20260819_080018.mp4
  • audio.mp3
tphoyt
I know a guy that had his lower replaced and somewhere along the way they disconnected the no oil alarm and the engine seized as a result. The shipyard that did the work owned up to the mistake and replaced the power head on their dime. I was impressed that they didn’t try to get out of it in anyway.
