arubanjames
Thread starter- Joined
- Aug 6, 2026
- 2
I am hoping someone here is able and willing to give me some assistance.
I have a 1985, 18’ Boston Whaler outrage. I bought 14 years ago it was a little rough but usable. The 2000 Yamaha F100TXRY (good compression and still does) had an idle sneeze and stumbled through the mid range, you had to massage the throttle or it would stall. But it ALWAYS started and ran WOT great! It has NEVER let us down!
When I first got it I had no idea how to clean a carb, so a marine mechanic buddy helped me, it ran a little better, and was usable for years. The I had to have them cleaned by another friend and this time I watched and then later successfully did it myself. Now I have done it a few times.
Then I decide to buy a balancer and try to balance the carbs, I am successful, but it wants to sound the overheat, so I get the meat thermometer from the kitchen and dial them into the safe zone that way. I had 2 great summers after that.
Then I could only get it to idle. It would just stall with any throttle (I just realize it may have been a tiny hole in the fuel pump diaphragm so they are on order now) So I bought an ultrasonic, and I had to replace a striped idle jet for the first time. I made the “mistake” of taking all the jets out and putting them in a jar together to clean. While all 4 carb bodies were cleaning.
Now I have all the jets and floats mixed up. Then I saw somewhere that the jets and floats might be matched to the different carbs depending on placement? And I’m wondering if before I got it they may have been mixed up? And that could have been part of the problem all along.
I can no longer read the writing on the jets, so do I need to order new ones? On the Crowley marine websight they only show one idle jet part number. But when the new one arrived it visibly looks smaller. Do I need to order a gauge? Do I want all four the same? Or small at the top and going bigger toward the bottom? Any help is appreciated!
Oh, and with the plugs out the sneeze looks like an intake valve is not seating, with the carbs off lots of carbon. So if I can get it running I have (illegal) Dealer only Yamaha Ring Free, to run in it.
Thank you!!!!
Thank you!!!!
