V6 240 impeller issue.
Signon
Hi. I changed my impeller. Went from a penta to a Johnson. On start up it started to heat up quickly. There wasn't a lot of water out the exhaust on the leg. I shut it down and took the cover off the water pump. The impeller is fine but the cover has a large circular groove on it that corresponds to the penta splines within the impeller. The splines actually move in and out of the impeller. I take it that it is not normal.
Also the impeller ends are different on both impellers. The Johnson has a groove and the penta doesn't.
It appears that the penta impeller may seal against the cover even with the wear. So which impeller is correct?
You can't buy the cover from volvo.
Thanks
Neil
Thanks
Neil
Ayuh,.... Welcome Aboard,....... That cover is junk,....
You either need a new cover, or a new pump, if you can't get a cover,.....
Volvo buys Johnson pumps.
Did you get the correct impeller for the pump?
Lou C
Impeller doesn't look right, the splines sticking out appears to be what wore the deep marks in the cover. Check part numbers carefully. Nothing but rubber should be running against the cover.
Signon
Yes the splines have moved within the impeller. It lines up exactly with the mark in the end cover. That is the penta one so I assume it is correct. To me, the impeller is faulty because of the movement.
Donald0039
Where did you get the new cover?
How did you decide which of the side of the impeller should face away from the engine?
Looking at the pump on the engine the vane at 12 o'clock should curl to the left or right.
Did you lube impeller with glycerin?
Signon
Hi Donald. New cover is from Joe Dupuis,
Rawpumps.com. Fits like it should. Slightly thicker than the penta, and made from stainless.
Johnstone impeller 09-812BT-1 lubed with dishwashing liquid.
I won't go back to genuine penta because of the loose bore which wore away the cover.
Also had a water pressure issue so flushed the heat exchanger and all hoses.
Now good to go. Whitsundays in two weeks.
Donald0039
How did the splines move within the impeller. It's one piece of rubber with a meal (bronze?) center.
I really doubt a Volvo Penta OEM impeller is wrong for your engine. But part number could have been looked up wrong or wrong part in the box or someone changed the raw water pump and it's not a VP OEM pump and needs a different impeller.
Again, VPs OEM pump is sourced from Johnson (an SPX Flow company)
They use the F6 and F5 pumps
