6hp Nissan 4 stroke powerhead gasket identification
reginaldo
In the attached pic is the part in the red square the power head gasket? Attached photo is from tohatsu.online if not does anyone know the proper part?
Am planning to remove the powerhead in order to replace the coolant water pipe and haven't done it before.
Thank you
reginaldo
Hi @pvanv , tagging you since you've helped resolve similar issues on other threads. Part of my confusion is not seeing anything on the exploded parts labeled "powerhead base gasket" while the "powerhead gasket set/kit" seems to contain cylinder head gaskets--would like to purchase only the powerhead base gasket and not a kit.
