2007 2101 DC. Windshield repair.
scuphunter07
Any tips on finding windshield parts for repair? I have a gap between my rounded windshield and the starboard wing window. Want to replace black diagonal support bar and reseat window in frame. Thanks!!!
Currently can’t close walk- through door due to misalignment and shifting of starboard windshield.
The windshield is most likely Taylor Made. They sell parts
Windshield support bars are pretty commonly available. The rubber gasket under the windshield should be as well.
If the windshield is racked, you should see what caused it. Sometimes it is the hull deforming. On my SeaRay, the hull spread a bit at the windshield and the hinged part would fall thru if I hit a wave. I riveted a piece of aluminum flat stock to extend the windshield lip.
