I have a Ns55b which is a Nissan 55hp outboard
Kneelan55hp
I was able to find a reference part for my impeller but even after blowing out my water lines it’s still not having any water come out of tale tell hole
reginaldo
Maybe the water pipe connection between lower unit and powerhead? I’d remove the thermostat and see if water is present/flowing through there.
pvanv
The telltale is not the end all of proof of flow.
I assume you got and installed
Impeller only.
Fits:
45A2, 50C, 55B, 60A, 70A & 70A2 2-stroke models
Part #: 353650210M
List Price (MSRP): $33.80
Your telltale may be blocked or you may have a bad water pipe as was previously suggested.
