Salt or brackish water
Deerhunter01
Hi, Im new here, I have never owned a boat. I am looking at a couple tracker pro guide v165 and v175 boats. They both have been in salt or brackish water. Both owners have said that they put in fresh water directly after and there are no signs of corrosion on the boat or trailer. One is a 2026 and one is a 2019. Should I stay away or further investigate? Anything in particular that I can check? Both boats look clean in the puctures. Thank you
Deerhunter01
Is it good enough to just run the engine with the muffs? Also, would any damage from salt or brackish water be visible or could there be internal issues with the boat or the motor?
DeepCMark58A
I would want the boat put in the water and actually put thru its paces. Also a compression test on the cylinders it is time consuming but you want to be sure, nothing more depressing when a new toy is broken.
aspeck
Boats run in salt and brackish water every day. That is not a problem, the problem is how they are maintained. I am a freshwater guy, so I am no expert, but I do not that pictures do not tell the story well enough. You need to see the boats in person. You need to see how they run and se underneath the skin. What motors are sitting on the back?
aspeck
the SeaPro line of Mercs are specifically designed for saltwater use. Are they SeaPro Mercs?
Whatever Merc it is, Mercury's maintenance guidance recommends flushing the engine with fresh water after every saltwater outing, rinsing salt from the exterior, and inspecting the sacrificial anodes regularly. Those are things to check/look for when you see the boat and motor in person.
Deerhunter01
Whatever they put on their pro guides. I don't think that they are set up for salt water. Thank you for all the help.
Outboards are pretty at home in salt water. They are mostly aluminum and are pretty resistant to corrosion. I run my OBs all summer in salt water, keep the boat hulls in salt water and almost never flush them during the season. They are 33 and 28 years old, respectively. They will not last the 50+ years of OB motors on fresh water, but they last long enough for me.
Lou C
You at least want to run it long enough to get the engine nice and hot, and check the oil for any sign of water in the oil. That, and carefully look over the power head with the cowling off for any signs of salt water leaks anywhere on the engine.
I'd also want to pull the drain plug for the lower unit to check for water in the gear oil.
redneck joe
Not just on muffs, always on the water. Similar to a car...you wouldn't just start in the driveway. Pressure test as well. Numbers vary between makes and models but at a minimum all should be withing a couple point of each other.
Welcome to the forum.
