2014 40 HP Mercury 3-Cylinder EFI - No Start
Yooper Fisherman
Hi all. New to forum. I have had this boat (2016 Tracker Grizzly 1860) and motor (see title) since 2016. Purchased brand new. Went to start it up this week to get ready for winter storage (with ear muffs in place and water on) and it won't crank. The starter Bendix pushes the pinion up and engages the teeth on flywheel, but doesn't crank (but tries too). Tried all the usual things:
- Checked/cleaned connections on battery, starter and solenoid
- New battery (12.71 V)
- Removed starter and solenoid and had them bench tested at a reputable "auto electric" establishment. Both checked out.
-Tried pull starting too, but I don't have enough strength to get through more than one compression stroke
Only thing I can figure is there is higher compression than usual for some reason, stopping the starter from cranking the motor.
My next step is to reinstall starter and solenoid, pull plugs and try cranking again. Maybe fuel leak into cylinder(s)?
Any suggestions?
View attachment Merc Start Video.mp4
alldodge
Welcome
You bought it new and this is the first time having this kind of issue
I would suggest start with the easy stuff. Pull plugs and crank to see if any liquid comes out. If no liquid, start checking Bat cables and connections. Could be a corroded cable/connection and full Bat voltage is not making it to the starter
Yooper Fisherman
Thanks alldodge. My thoughts exactly. I've been through all the connections from the battery to the solenoid and starter so far (the relatively easy ones to get to). Ground points and other connections inside the motor housing will be a pain, but gotta do what I gotta do! Yes, bought it brand new and the 1st time I've had an issue like this. It's been a solid watercraft to this point.
One point that I need to pursue as well: I read somewhere that my motor has some kind of "compression release" during start up. Have no clue how it works, but maybe another avenue to investigate. If that is in fact the case, would make a whole lot of sense (my little pea brain talking).
Positive waves always!
  • donald-sutherland copy.pdf
Yooper Fisherman
Still getting used to attaching files. A classical reference.
Yooper Fisherman
Reinstalled solenoid and starter (cleaning connections thoroughly in the process), pulled the plugs and cranked (see attached). No fluid whatsoever. Not being an outboard expert, I would expect a faster cranking rotation (with no plugs) than what I witnessed. Starting to think maybe starter or solenoid are actually suspect (even after having them bench tested). I sure hate to "parts change", but maybe it's time to purchase a new solenoid and starter and try replacing them one at a time? I know I said that the solenoid was checked, but it actually was not, only the starter. I figured (and maybe the tech at the auto electric establishment) that since the starter was engaging the pinion to the flywheel, the solenoid was ok. Could the solenoid be suspect and not delivering full voltage? I understand mechanics, but not electrical stuff so much.
View attachment Plugs Removed.mp4
Mc Tool
Do you have a multi meter , if you do set it to dc volts and put one probe on each of the solenoid main terminals ( the one from the battery and the one to the starter ) and crank the motor ...the volt meter should read zero or very close to it ...like no more than 0.1 or 0.2 v . If you get a reading of a couple of volts the solenoid is suss . This reading is telling you how many volts you are loosing over the solenoid , known as a " volt drop test " . You can do this anywhere in any circuit to test for bad connections , the power has to be on , you could , for example put one probe on each side of a fuse to see if the fuse is blown ( you would see battery voltage if the fuse was blown ) or even to check that the fuse connections are good and not corroded .
Google it up " volt drop test " its a real handy thing to know when diagnosing possible faults in circuits.:)
Yooper Fisherman
I do indeed have a multimeter! Great info Mc Tool. Just the info I was looking for. I will try it tomorrow and report back with the results. Would much rather work the problem. Not make things worse by guessing!
