redneck joe
Thread starter- Joined
- Mar 18, 2009
- 16,562
with a canvas cover. a bit early but it needs a shaft seal and i've got enough things to do until next spring. Had one good day and one ok day on the water this year so calling it good. Winter will be building a deck down at the river ....
Never not had a covered place to put the boat. Thankfully this one came with the cover just never had a need to use.
Plan is to put two small fans underneath - one on each side of the center console with one facing forward and one to the rear. 12v, will hook to battery and have a small solar panel coming (with a BMS) hopefully to keep topped off and not have to use charger.
Question is this - i've seen solar powered fans that get put thru the canvas. Are these worth the money and effort?
