350 cam
Cpotter78!
I have a 79 24' SeaRay im rebuilding the 350 in it and need cam recommendations. I wouldnt mind some performance but I dont want to modify the heads, they are already done.
They are Torquer iron heads
Scott06
your current heads are going to be down on power compared to the more modern ricardo combustion chamber found in vortec's etc. however you have them. The torquers are heavier (thicker) than the vortecs, and while they have larger valves, they flow more than the old chev castings, just not as much as the vortec.
did you at least do a proper piston, or did you stick with the cast flat-tops with the 4-piston reliefs?
with any cam change on a boat motor, you need to stay below 270 degrees of duration or you end up sucking water into the motor thru the exhaust.
I would highly recommend a roller motor myself. however for your old flat tappet motor.... I ran a comp cam - the CL12-236-3 - Comp Cams 'Xtreme Marine' Hydraulic Flat Tappet on the 350 in the Rogue prior to going porkchop
Operating Range: 1300-5500 RPM
Duration Advertised: 262 Intake / 268 Exhaust
Duration @ .050'' Lift: 218 Intake / 224 Exhaust
Valve Lift w/1.5 Rockers: .462'' Intake / .477'' Exhaust
Lobe Separation Angle: 112
ran it with summit 1.52:1 roller rockers when I did a vortec head swap and a Volvo Penta marine intake (same as edelbrock marine intake). I should have gone with 1.6's as I had room on the PTV test.
with any flat-tappet cam. the first 20 minutes of break-in are critical.
Cpotter78!
It is a flat tappet and sucking in water is what i was worried about I did get speed pro pistons with the 4 reliefs and dished its been bored 30 over as well I also have a edelbrock torquer 2 intake and a edelbrock 650 carb i should also ad the motor is a 350 out of an old truck it was blue from the factory the original mercruiser was replaced before i got it
alldodge
Check your height of elbows to water line, need 13 inches minimum. Also if you get several folks sitting on the stern when anchored, might need it a bit higher
My experience is 650 cfm is too small for that cam in a 350. I was running a 750 cfm as that is what VP supplied with the stock 271hp and 290 and 310 HP motors. And spinning higher rpm and more power required more fuel
Agree with ADs comment on riser to SWL
The torker 2 intake you mentioned is not a marine intake, so I would be concerned about corrosion e end in fresh water
Since the motor came out of a truck, make sure you swap the head gaskets to stainless MLS, and core plugs to brass and water circulation pump to a marine unit. The truck cam is pretty much a boat cam
Which heads are you running? Old SBC boat anchors or vortec heads or other good flowing heads with the ricardo combustion chamber?
Scott06
Both VP and Merc used 750 cfm carbs on their 350 engines. A lot of places like Michigan motorz will sell their partial engine packages with 600 cfm carbs but that is the stock cam.
Also agree the Torker is wrong for this set up, not only corrosion but intended rpm range as well.
VP makes a great 4 bbl intake, but that may be for Vortec heads only. Would be a good time to upgrade to vortec heads and pick up some power with out going to wilder cam etc
the VP manifolds and the Edelbrock marine manifolds come out of the same casting house with the same cores. they both made at buddy barr castings.
the edelbrock 2504 is for the 1986 and below
the edelbrock 2506 is for the 1997-1995 heads
the edelbrock 2516 is for vortec heads
Since the whole world thinks these VP manifolds are gold and asking up to $1000 for a $500 manifold, buy the edelbrock marine version from Summit with one of their christmas deals.
or buy the PCM version (also comes from Buddy Barr)
