Optimax help
dom88
Hello i need some help. On my 2003 150 optimax i replaced my water pump and poppet valve, after a few mins im getting water coming out the rubber grommet and light white smoke, is that normal? I was getting a loud horn after going past 7mph but when i removed the cowl i noticed a water sensor and wire on compressor sensor unplugged, must have got snagged on cowl when i put it on so i assume and hope that was the reason. Appreciate any help.
  • 20261025_100356.mp4
Gee, the video looks and sounds pretty normal. Your owner's manual or a service manual should tell you the code for the alarms. I had thought (could be incorrect) the water separator alarm was beeps, not a solid tone. A solid tone is usually overheat. There are other alarms for limp mode and low oil.
Your motor likely has 2 thermostats to control cooling water temp at RPMs below 2000, and a poppit valve for higher RPM. These could need replacement, if you detect overheat.
A simple test is to run without the cowling and when the alarm occurs, put your hand on the cylinder heads and see how hot they are. A normally cooled motor will allow your hand to remain on the head for several seconds. Of course, i you see burnt paint she is overheating badly.
Mc Tool
You should get water out of the indicator ( that grommet ) pretty much instantly when the motor is started , few seconds at the most , and no smoke . I think you might need to remove the gear case and have a look at where the pump outlet connects to the tube going up to the motor . Make the tube is actually going into the pump outlet and make sure the tube is not pushing the rubber seal down into the pump . If there is a rough end to that tube it can snag on the rubber seal .
