Hot Take: A boat wheeled and waxed in spring is no different by fall
deeman7777
Walking the boat yards in the spring with the boats on the hard, it's impressive to see the shine some of the hulls have after a nice wax job. Especially from ground level looking up at the hull, it's super impressive.
However, if you walked the docks in the Fall and viewed the boats in their slips, I feel there is very little difference between a boat waxed in the spring vs other boats which have not been waxed in several years.
Agree?
crazy charlie
Totally disagree!!! Totally!! I wheel my cruiser in the spring and ceramic coat the wax.I also put a coat of wax on in the fall after hauling and wrapping and I leave that coat of wax on thru the entire offseason. My hull sparkles and beads water the entire season and looks entirely better than way newer and more expensive boats that have not been waxed/polished. Not even close. Charlie
JimS123
All my boats are garage kept. My oldest is 74 this year, so there's no way she's gonna stay outside, covered or not.
My Fall regimen is to park the bot, winterize, air the trailer tires and repack the wheel bearings, polish the hull and upholstery, fill and stabilize the gas tank and put on the cover. I crack the back of the cover monthly to top off the battery.
Come Summer the cover comes off and she's ready to go to the launch ramp without any further adieu.
Leave her dirty and unkept all Winter and the Spring tasks are harder.
Grub54891
A lot of people wait until their boat gets chalky, then decide that it needs wax. Not a good idea. Once it gets chalky it really needs a decent wetsanding and buff, then wax. Even at that it will look like it did after a season in the sun. Gelcoat needs wax or a good sealer from the get go. Once it’s comprised it’s almost impossible to bring it back and stay looking good.
alldodge
Had a 1995 Formula 27PC and never waxed it, just wash. Folks at my dock always commented that it looks like it was just waxed. Expect the same from my new one
Lou C
I thought Formula hull sides were not colored gel coat but sprayed in Imron.
airshot
My boats have been aluminum hulls for the past 60 years and keeping them stored inside skies the aging process to a crawl. Yes I also wax ( spray on stuff) to help the shine and slow the oxidation. Current Sylvan is wrapped above the water line on tip if a painted hull. 1992 and still looks awesome.
If you want you boat to look good then lots of elbow grease or inside storage will be a must do !
Pmt133
Trying to get the oxidation out of something that was taken care of 6 months ago is an order of magnitude easier than something that hasn't been taken care of in several years. Been there. Done that. Even wet sanding can be futile if it's gone a long time with no care. I've done several that were too far gone to even look decent.
As was also said, there are quality differences too. Whatever 4winns was using in 84 is bar none the best gelcoat I've worked with outside of something painted or formulas. Darker colors need more care and obviously garage kept makes things last a lot longer.
If someone walks past my vessels and says they look the same as something that wasn't even cleaned, I probably died as that's the only logical explanation.
crazy charlie
Not sure what any of that has to do with the topic..??
Hot Take: A boat wheeled and waxed in spring is no different by fall​
dingbat
Being a SW guy, maintenance and upkeep throughout the year isn't optional Pretty easy to tell who gives a darn and who doesn't by Memorial day.
mr 88
I've never waxed a boat in the 60+ years of boat ownership . I use my boats ( have owned over 30 ) and don't have the time or care to polish the hull . None of my boats oxidized, so no chalking . I think i washed the hulls once or twice in the spring , 20 years ago . I keep the interior clean , and 100% on top of driveline maintenance.
