280DP
PatinIdaho
Ordered a drive coupler today.
As long as everything fits togeter i'll be into this swap $690 so far.
Still need to order a transom gasket and a water pump so maybe $200 more.
I can't think of anything else except 33C control cables if the ones i have are not long enough.
Scott, how much HP/Torque are you pushing through your 1.95 ratio drive?
PatinIdaho
Made an outdrive stand using my super non existant woodworking skills.
Drained the oil and it actually came out looking pretty good.20261118_121020.jpg20261118_122744.jpg
PatinIdaho
Got the flywheel. Hope it is the correct one.
It is 12-3/4 inch
153 tooth
2 piece rear main
PatinIdaho
The flywheel matches up to the old one except for the weight for external balance. Im sure it is the right one.
I ordered a 6 bolt coupler and it is a little too small. The others I find are too large. Looks like i need one 12-1/4 diameter.
I put the old 3 bolt coupler on the new flywheel and it fits perfectly.
I wonder, did VP use the same coupler on both 5.7 and 454?
SBCs and BBCs share the same bolt pattern. Make sure it's for a BBC, or the imbalance will take out the bearings
The 4.3, 5.0, and 5.7 (below 290hp) got the 3-bolt triangular drive plate. The 5.7 above 290 HP and 7.4 liters got the 6-bolt round drive plate
PatinIdaho
Yeah. It's for a 454.
I ordered a large coupler and will get it cut down. Pretty sure that is my only option.
I think the problem is VP did not use a 454 with AQ until they came out with the updated gray cover that fit a large flywheel? In 1994 i think.
They had the 7.4 liter from 1988-1992 as the DP740A with the smaller 153 tooth in the same PDS housing Then there was a minor change for the 740B for 92-93. The drive plate 856346 is NLA
It was attached to a DPB1 drive ( minor changes between the DP290, DPA thru DPH)
