I agree and love my two speed manual winch....but the heading states "electric winch"....so......?When sizing a winch, consider that winches are rated (max capacity) with an empty spool.
As you add wraps, the pull capacity drops and the your effort goes up.
I always go with the largest 2 speed that fits the winch stand. Your shoulder will thank you for it
Worst yet….the hp input is fixed. You can’t crank harder as the winch fills up.I agree and love my two speed manual winch....but the heading states "electric winch"....so......?
bunks/rollers/ramp angle?Worst yet….the hp input is fixed. You can’t crank harder as the winch fills up.
My boat weighs @ #4,700 unless I have both fuel tanks filled for an offshore trip.
Had an electric winch rated at #4200 of pull. Winch pulled boat well to about 1/3 of the way on the trailer. By the time the boat made it to the winch stand there was nothin left. Had to pull the trailer to level ground to snug up the cable for the trip home.
With that experience under my belt, I would not buy an electric winch rated any less than the weight of the boat.
32 roller trailerbunks/rollers/ramp angle?
The other “small print” in winch ratings nobody reads.I have only witnessed two electric winches in use on boats in all my boating years. I considered moving to electric a few years back due to bad shoulders. Watching others use electric winches, they apoeared pretty slow.
The issue with an impact wrench is going to be the rpm.so i'm thinking, both on my winch and tongue jack to have the opposite side operable to be able to use my impact wrench. The jack has enough meat on the pin to grind down to like maybe a 3/8" drive the winch would need a different approach as it is flush.
That will not end up well....if it even works. I have a tongue jack that was made on purpose to operate with a drill. Not recommended to use an impact.so i'm thinking, both on my winch and tongue jack to have the opposite side operable to be able to use my impact wrench. The jack has enough meat on the pin to grind down to like maybe a 3/8" drive the winch would need a different approach as it is flush.
why?That will not end up well....if it even works. I have a tongue jack that was made on purpose to operate with a drill. Not recommended to use an impact.
I had back problems in 1984, so I bought a Powerwinch to replace the OEM TeeNee (Fulton) 2-speed manualwinch. Had that unit for 35 years and when I sold the boat it was still working perfectly.32 roller trailer
Ramp angle ~ 8 degrees
The issues isn’t the ramp, it’s the way marine winches are rated.
In my case, I needed ~25’ of cable to get the boat off the trailer but only needed 8’-10’ cable to get it back on. That 15’-18’ of extra cable on the drum cut the capacity in 1/2 before I even connected the boat to the winch.
Not my winch but clearly demonstrates the issue.
I don't believe the fears would last long from the hammering effect of the impact tool. I use one often but is variable. I have experienced a number of nuts and bolts getting damaged from the hammering effect. There are some things made for an impact but others are not.so i'm thinking, both on my winch and tongue jack to have the opposite side operable to be able to use my impact wrench. The jack has enough meat on the pin to grind down to like maybe a 3/8" drive the winch would need a different approach as it is flush.
