sumocomputers
- Joined
- Feb 23, 2015
- 123
Rebuilt the carbs on my '89 Johnson 70, and replaced all 5 gaskets. 3 between carb and block, 1 between carb and silencer, and 1 between silencer and cover.
I ran the boat a few hours after the rebuild, and inspected the inside bottom cover for fuel leakage, and it was spotless. We trailered the boat and of course tilted the motor up manually for storage.
Fast forward a week later, and now I have a fair amount of fuel in the bottom cover, and the source of leak seems to be at the gasket between the carb and silencer on all three carbs (see photo of gasket now removed). Also, the inside of the cover had fuel spray, and that gasket was also a little moist with fuel, so I think the fuel may have leaked from the bottom of that as well.
I installed all the gaskets dry, according to the service manual. I tried to tighten as evenly as possible when installing, and if anything I might have overtightened just a hair. No I didn't have a torque wrench.
So is this normal, or do I have a problem? I don't mind a little fuel if it is normal, but it just doesn't seem right to me. I have another new one of these gaskets if I need to do something different.
Thanks,
Chris
Thanks,
Chris
