New guy with new guy problems. When doing a lower unit seal/impeller change, I removed the reverse lock cam and now I have no idea how it should go back on. I’ve tried a couple different things, but it doesn’t seem like I can shift my lower unit into reverse even if I rotate the prop while I try. If it helps, my serial number is 5480528. Any advice here? Thanks!
Jake
Jake
