Brock O
- Joined
- Dec 26, 2014
- 60
Hi Guys,
Firstly great forum! I've been reading for a few months but now have to ask a question or two. This my second boat and of more age than the first so have been doing all work myself using the manual and this forum for info.
Its a 1995 Johnson 115HP, 2 stroke model TLEOR, hopefully I'm adding this to the right section, I've been throwing parts at it for piece of mind as its been problematic since the rushed purchase, lack of maintenance in most cases it seems. Any way, after putting carby kits through and having the boat running sweat at WOT 5500rpm all problems seemed to be behind me, after settling back to idle and turning the motor off to see how the restart would be at temperature the problem occurred, it started with a rough idle and a max of 3500rpms from then on.
New plugs, leads and coils had previously been fitted but when pulling the plug on one cylinder the motor would not change note, the plug had came up black and oiled so my thoughts were the lead or coil, I would get a kick when pulling the coil end of the lead but nothing at the plug end, I can hear the clicking sound when refitting the lead but no change to the motor's performance, change of plug brought the same response. After performing a compression check today left side 109 & 109 right side 99 and ZERO, motor makes a totally different sound when checking this cylinder, now during the previous run at 5500 I herd no clunking or banging...excessive smoke or cooking smell. Even during the compression test with the motor hot, there's no signs of leaking at the gaskets, oil or fuel leaks to that cylinder....could broken or stuck ring's give an absolute zero reading ? or am I missing something. Compression kit was brand new, tried this a few times over a Few cylinders as I thought something must be wrong
So your thoughts on the problem would be great.......I'm reading the mechanical section now in preparation of an overhaul, would it be wise to remove the cylinder head for inspection first before pulling the Power head off, and are there any trick's to pulling down this motor other than following the manual's procedures ?
Any thoughts greatly appreciated, I think I'm 12 hours ahead so will be late on reply's.
Brock
Brock
