'01 Suzuki 70 where's fuel vapor seper. located?
mudball
Where is the fuel vapor seperator located and can it be accessed by just removing the hood? I've referenced the parts diagrams, but they don't show an overview to locate it. Thanks in advance.
lakensea
Re: '01 Suzuki 70 where's fuel vapor seper. located?
It is located between the engine block and the intake runners. About the only thing you can acess without removing the intake system is the drain screw - locate the pink drain tube and follow it up to the bottom of the VST.
jstachowiak
Check this out: <br /><br /> web page <br /><br />You'll have to create a login, no charge, then go to parts, then your engine. PDF files of parts manuals with detailed drawings. You will find all your looking for.
