01 yamaha 115 2 stroke lost spark cylinder 2 & 4
cuenta
Hi guys .
I have a yamaha 115 with ignition problem
I already check the spark with a inline spark tester and only have strong spark on cylinder 1 &3 but cylinder 2 $ 4 the none .
I hope your help.
Thank
boscoe99
Two pulser coils firing four cylinders.
One two-wire pulser coil fires two separate
cylinders at different times in the firing order.
cuenta
I just check the resistence on stator
Brown to red. = 915 ohm
Blue to black/red = 80ohm
Pulser.
W/red to w/yellow. = 320 ohm
W/green to w/black = 317 ohm.
Today I order a dva peak tester .
Faztbullet
Your engine should have the lost spark ignition ...as in 1 & 3 fire at same time as does 2 & 4.
cuenta
1 & 3 fire strong but 2 $ 4 nothing or very weak . To my eyes.
Yesterday I swapped the ignition coil 1 to 2 and 3 to 4 with the same result 2 & 4 not spark
cuenta
I just received the dva adapter, someone can clarify some doubts. for example the meter must be in A/c . Or d/c
99yam40
should be dc from what I remember
there is a cap, diode, and resister in there
but if that does not read properly it would not hurt to take a reading on AC just in case
cuenta
Stator test .
Brown to red. = 275 volt
Blue to black/red =75 volt
Pulse. Test
W/red to w/yellow. = 5 volt
W/green to w/black = 5volt.
I think the stator and pulse are good.
someone knows how to test the output of the cdi and the values
boscoe99
Stator test .
Pulse. Test
Is this a question or a statement?
99yam40
Stator test .
Pulse. Test
I would think the same place you found the specs/info on the charge coil and pulser coils would have the info for the CDI outputs
Service manual
