So the backstory. First time out this year since Sept. (Long winter!) Unloaded at the ramp, and the engine was more finicky than usual. Died idling a couple of times even. It died 4 times idling in the bay but seemed to clear out, so I just chalked that up to old gas. Cruised for about 15 minutes, and it dies again, and this time it won't restart unless I wait about 15 seconds or so. (And nearly immediately dies again.)
Luckily, it died in front if my own dock, so I was able to change the main fuel filter, same results. Had a neighbor tow me back, and during the tow I checked the fuel filter in the carb. Spotless. I also bumped the key with the fuel line off to see if the pump was good, and fuel shot across the engine!
Anyway, reattached the line, let the bilge air out, and restarted it. This time though, it didn't die, in fact I stopped my tow, and ended up boating for another two hours, anywhere from idle to WOT, not a hiccup.
Any theories? I don't like when a problem fixed itself. My only theory is that the fuel pump somehow either was stuck/weak, and when it was able to pump without restriction it freed up. (Or a air bubble in the pump?)
