'02 Merc 3.3 won't run above idle in gear
timjet
The motor seems to run fine in the tank in neutral and will run at above idle throttle, but when I put it on the dink and put it in fwd gear it won't run much above idle. It hesitates and runs rough and generally quits. No problem starting again but same thing happens when I put it in gear and increase throttle. I've tried adjusting the needle valve but it doesn't seem to make much of a difference.
Suggestions??
