'02 Nissan 120,#2 not firing, otherwise runs fine
opd733
Motor runs rough at idle and will not run good at w/o throttle. I pulled the plug wires one at a time while running and #2 is the only one not firing. I swapped the #1 and #2 coil wires and plug wires and #2 still did not fire. I pulled the #2 carb and cleaned it out just to be sure, but there is fuel in the cylinder, plug is wet. Any ideas?
PS. I am new to this forum, so if I get something wrong, work with me. I am better with a wrench than a computer.
TOHATSU GURU
Re: '02 Nissan 120,#2 not firing, otherwise runs fine
Get a factory service manual and then check the ignition system using the test procedures and values found in that manual.
opd733
Hey, I think I have it narrowed to a fuel delivery problem, could a reed valve keep it from firing like it is?
TOHATSU GURU
Do you have spark on number #2?
