Pursuit2550
- Joined
- Sep 20, 2007
- 73
Like the title says. I was doing some maint. to my engine oil tank and I decided to take it off and clean it. Anyways I take it off and i go and clean it. When I get back to install it this is what I found. Now about the engine. When I bought it it had 189 hrs. It shows from the out side, everything is almost like it just came out of the factory. When I bought it (used) I did the regular maint., changed water pump,filters,t-stats, etc. Now when I took off the t-stats I noticed corrosion where it sits. I dug into it and it poked a hole into the inside cavity of the engine. No problem I grinded it out and put JB Weld. Today I saw this the exact same thing as the t-stat housing, only on the outside. I also took out the t-stats and the JB Weld is holding just fine. Only thing is that there is still noticeable salt and corrosion where the t-stat sit. Now I flush my engine evertime I get back from boating, so why is there this salt and corrosion in there. Why did it corrode like that on the side of the engine? I already did the same JB Weld job on it, but I am afraid the engine is corroded inside. What do you guys think? I think the guy that had the engine before never flushed it.
